superrayzor wrote:
I have a class a mh and can pull up to 5000 lbs. right now i am towing a honda odyssey but it is 4300+ lbs and I would like something lighter.
sorry...you're assuming that you can pull 5000-lbs but unless you know what your MH weighs as it is loaded for travel you can't be sure.
in general, the maximum amount of weight you can safely tow will be the lesser of the following:
- the GCWR (gross combination weight rating) of the MH minus the actual weight of the MH as it is loaded for travel (includes fuel, fresh water, food, clothing, people, pets, supplies, etc.)
- the weight rating of your tow bar
- the weight rating of your hitch
this is why it's vital to know what your MH weighs as it is loaded and configure for travel before choosing a toad. Your MH will not collapse if it is overloaded but you will experience handling issues as well as longer braking distances and accelerated wear on suspension, brakes, steering, etc.
in any case I doubt you're going to find a 6-passenger vehicle that's lighter than 5K much less lighter than 4300-lbs.
