SilverEscape's avatar
SilverEscape
Limiting factor on GVWR for trailer
This isn't exactly a towing question but not sure there was a more appropriate forum?
We noticed our trailer has axle ratings of 3000# each, so 6000# total. And the tires are rated for 1610# each, of 6440# total. The coupler is good for 1500# tongue and 10,000# trailer weight. Our trailer has a GVWR of 5500#.
When we weighed the trailer last time, hitched up, it was 4850#, so not close to the 6000# the axles could carry or 6440# the trailer could carry.
Wondering what is creating the limit of 5500# and why they didn't give this trailer a 6000# GVWR which seems to me would still keep it under the axle and tire limits.
  • SilverEscape wrote:
    Old-Biscuit wrote:
    Because Jayco rates GVWR by the sum of UVW plus CCC
    UVW...4,005
    CCC...1,495
    GVWR..5,500
    Then I'm asking where the CCC comes from. Why not 1995? The axles and tires can take it. Because we all know that the trailer that shows up at your door isn't 4005#, so you're CCC isn't going to be 1495#. Why not give more if the components can take it. Something must be limiting it. Frame? Suspension? I don't know enough which is most important in determining CCC.
    Then contact JAYCO and ask WHY oh WHY have you done this :H
    UVW...4,005
    CCC...1,495
    GVWR..5,500
  • Because Jayco rates GVWR by the sum of UVW plus CCC
    UVW...4,005
    CCC...1,495
    GVWR..5,500
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 13, 2026
