luberhill's avatar
luberhill
Lippert auto levelers hose leak
Ok notice the front retract hydraulic hose has a bad spot and it’s dripping,, it says 24865430
Do I need to go to Lippert to buy ??
  • Retract everything with it hitched. Fill to proper level then cycle everything a few times and top off if needed.
  • Got the new one made 56.00 but a much better quality
    Now to see if it gets air in the system
  • Have you tried tightening the fitting or is it actually a hole in the hose? Very normal to need to snug up the fittings.
  • Maybe. Replace the hose, then extend the leveler and watch it. If its slow to react, crawl under and crack the fitting closest to the ram and let the air out. Generally you wont have to do anything except replace the hose.
  • donn0128 wrote:
    Oh heck NO!
    Take it off, take it to a reputable hydraulic hose shop. They will make you one up pretty reasonable. If you cant find a hose shop, find some place that does hydraulic work.
    Gotcha found one close by, assume I will have to purge air somehow ?? Or do I call them and have them walk me thru it
  • Oh heck NO!
Looking for advice before your next adventure? Look no further.25,181 PostsLatest Activity: Jan 22, 2026
