IH_Fan's avatar
IH_Fan
Long term storage
Hi Folks,
Here's the context to my question:
We have a 39' fiver, with all the options, 4 slides, and commercial fridge. Every spring we head to Myrtle Beach for a couple months, then a week or two closer to home (I'm in Ontario, Canada). We have indoor storage for the fiver in a machine shed, insulated with concrete floor, but not heated. During storage, it's out of the elements. Context is done:
With the pandemic, we didn't go anywhere with the fiver and it remained stored. The border closed and local camping this past summer just didn't work for us this year. That means the fiver has been sitting since May 2019. I'm getting nervous of it sitting for so long. I inflated the tires to max (80 psi) to help reduce tire flattening. I also have the tires on mats to avoid direct tire/concrete contact.
I'm wondering if I should pull it out and run all the systems for a day or two, or simply leave it alone. I have not gone this long without using it and hope that the world is somewhat back to normal next spring.
Thoughts???
  • I'd take it for a spin just to fight the pandemic boredom.
    I'd use this time to go through it from top to bottom and make a list of anything that needs attention.
    I assume you don't have an onboard gen, otherwise you would have been exercising the gen every month.
    If you have the time, go say "hi" to it in storage and make it feel loved.
  • Gdetrailer wrote:
    Leave well enough alone.
    It is stored indoors out of sun and possibly extreme cold weather/winds/snow/rain ect.
    Tires do not "need" to be isolated from concrete, wood, stone, gravel that is nothing more than an old "wives tale".
    As long as your storage does not have extreme moisture concerns, I do not see any reason as to why you would worry about "running" things like furnace, fridge and so on just for making sure..
    As far as wheel bearings, they are reasonably sealed from moisture and they should have plenty of grease and you are storing indoors, there is no reason to go to the hassle of hooking up and towing 10 or 20 miles.. They will not go bad or freeze or break sitting.
    Tires losing pressure is normal, 1-2 PSI per month is considered normal, simply add pressure to sidewall max rating periodically which you have already done.
    You didn't mention the battery, as long as you have a multistage converter, leave it plugged into shore power or disconnect battery and use a manual charger once every three months.
    Thats it!
    By the way, the 30+ yr old TT I am using sat on a campground lot for 10 yrs before I bought it. All I did was fix a broken brake wire, replace the breakaway switch and add pressure to the crusty cracked tires and towed it home 18 miles that way..
    ^ This 100%. Batteries and mice would be the only 2 things I'd be concerned about.
  • Lwiddis wrote:
    Yup, get it out and drive around for an hour and run every system. Flush the fresh water tank, water lines and water heater.
    And please for Lwiddis sake, post a youtube vid of yourself driving a 5th wheel trailer!
  • MFL wrote:
    IIRC...you posted pics a while back of your pitted bearings! This is mostly do to sitting long term. You claimed cheap bearings. Yes, some bearings are higher quality than others, but most will serve you well, if you take care of them, and best to use them, not letting sit long term. The tires will also benefit from a good warmup.
    I do agree, the bearings will not break or freeze! :S
    Jerry
    Sorry, you have the wrong person.
    Never posted pix of "pitted bearings".
    Never claimed anything about "cheap bearings".
    There are folks who insist on special name brand bearings, the reality is those more expensive name brand bearings come from the exact place the cheaper bearings come from and a good chance from the SAME factory.. China.
    I did once have an issue with bearings on a 4x2 truck, the vehicle manufacturer made a cost savings move to reduce the lip the grease seal touched.. That allowed water to easily make it's way into the bearings and grease. The grease was full of rusty water.. Had noting to do with quality of bearings though.
    Jerry
  • If you winterize with pink stuff, I'd add some more. If you air-blow it, I'd leave the plumbing alone.
  • Leave well enough alone.
    Thats it!
  • I’d rather know now if any appliance has given up the ghost rather than wait until I was ready to go camping. Plenty of time for repair.
  • Being stored inside, I'd not be concerned about operating appliances. I would be more concerned about turning the tires/bearings. I'd tow it at hiway speed for 10-20 miles. To do this you would have to operate the landing gear, and while out, you could also run the slides out/in.
    Jerry
  • Yup, get it out and drive around for an hour and run every system. Flush the fresh water tank, water lines and water heater.
