Fliposo's avatar
Fliposo
Long Uphill Pull
Will be pulling Berthoud pass in Colorado soon. It's a fairly long pull with some tight U-turns. Truck is an '08 Dodge Ram 1500 QC, 5.7 Hemi..auto trans with T/H mode. TT is an '09 Jayco 23FB, weight 7000#. What would be the best gear to use? Thanks
  • Pick a gear that makes your engine happy. Not lugging or revving at red-line. The drive-train will run cooler if you rev enough to move air with the fan and circulate water. I have a 6-speed and use all 6 depending on conditions. Have fun.
  • I would pick a gear that lets you pull with a steady speed with the transmission locked up. Try to use the same gear or even lower when going back down.
  • When I had my truck and TT, my truck didn't have the T/H feature so I would do as smkettner said and keep the rpms up around max torque... in my truck that was around 3600 rpms. In my experience, it was the trans temp that I really had to watch rather than the engine's.
    Ron
  • Use the gear that keeps you up close to 4000 rpm.
    Use the lever to minimize hunting, especially at full throttle.
  • Put the transmission in drive (overdrive off) and use tow/haul mode. I suspect the truck's computers will select second gear uphill, which means you should also probably use 2nd gear down for the engine compression braking.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
