At 35MPH I hit an unexpected dip in the road over the weekend and noticed the washers were loose while in hooking. I adjusted and re tightened bolts. Does this happen often?
Yes I found the tilt washers loose. The bolts that hold it tight have teeth for grip. The truck hitch should be fine but I will get a closer look at the frame and welds before we go out again. I tightened up the bolts at our site and seem good after the ride home.
Looking for advice before your next adventure? Look no further.25,207 PostsLatest Activity: Aug 26, 2026
