Pool
Jun 25, 2013Explorer
Loose hitch
At 35MPH I hit an unexpected dip in the road over the weekend and noticed the washers were loose while in hooking. I adjusted and re tightened bolts. Does this happen often?
Pool wrote:
Yes I found the tilt washers loose. The bolts that hold it tight have teeth for grip. The truck hitch should be fine but I will get a closer look at the frame and welds before we go out again. I tightened up the bolts at our site and seem good after the ride home.
