John_Wayne
Jun 16, 2017Explorer II
Extend the tube so it is higher then the tank. Or extend it to the fill side of the trailer and put a shut off on the end. When filling the tank when the water starts to come out the over flow tube you just extended shut the valve. When you get set up at camp you may have to open the valve again so the tank can get air so it doesn't crate a vacuum in the tank, when using the pump.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
