Lynnmor
Jun 17, 2017Explorer II
The hose labeled Vent Tube may be connected to the vent next to the fill cap, maybe you can disconnect it and blow thru to test.
If there is a way to pressure fill with city water connected, one vent is not enough and doesn't meet code. Perhaps the second hose was added for this reason. If there is a way to simply route the black hose up and out, that may be all you need. Just remember that the water tank is not a pressure vessel and does need adequate venting.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
