takaya49's avatar
takaya49
low point valve hole
I have a hole in my low point valve. wonder what the best fix is? Its about a 1/8" hole
  • Can you at least tell us what material it is made of? A picture would be wonderful, every brand has a different type of drain.
  • beemerphile1 wrote:
    All my low point valves have holes in them, that is how the water gets out.
    replacing this is as easy as?
    this is the drain pipe to the fresh water system. I cannot get pressure with this hole to use my taps as the pump keeps slugging..
    is it as easy as twisting it off?
    its in the middle of the trailer. no access to where the pipe meet the fresh water tank unless i take off about 30 screws to the thin metal under the trailer..
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Feb 27, 2025
