jstaffon
Sep 30, 2018Explorer
LP Auto ChangeOver Regulator
I have the typical auto changeover regulator on my 5th Wheel. You select the tank you want to draw from and it tells you when the tank is empty and then automatically starts drawing from the other tank. On the opposite side of the RV there is what looks like another regulator installed in the line leading to the auto changeover regulator. What is that for? Is it necessary or overkill? Can it be removed? What is the part name so I can order a new one? It appears to be leaking.
Also, what is the best thread sealant to use on the hose threads? Thanks in advance!
