- theoldwizard1Explorer IISomeday, we will be able to purchase GOOD RV heat pumps, ones that will produce heat down to zero F (like mini-split heat pumps that have been around for decades).
One more nail in the coffin for LP in an RV ! - Michelle_SExplorer IIII have twin 40 Lb Tanks and those things are heavy when filled. I'll use electric every chance I get to avoid having to refill those beasts.
- blaczeroExplorer
HappyKayakers wrote:
I found this link several years ago. Can't vouch for the figures but it looked like someone did their homework. http://www.adventure.1tree.net/index.php?option=com_content&view=article&id=292&Itemid=285
Good info everyone thanks. Great link too.
I'll do some calculations and go from there.
The inconvenience doesn't factor in, since my campground has propane fill and it's $25 for a 30#'er. - LantleyNomad
I assume you have permanently mounted tanks and they come to you with a truck. Otherwise there is a convenience factor. Even then you have to arrange for LP, pay for it and meet the driver to fill tank.
With electric there is no interaction. NONE. - Old-BiscuitExplorer III
OP stated
I would assume portable propane cylinders - LantleyNomad
OP stated
If the OP has portable tanks, than there is a convenience factor. Unless the CG changes the tanks for him for free, otherwise the OP has to physically put in the effort to swap the tanks. - philhExplorer IIElectric is easier, end of story
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
