JoshuaH's avatar
JoshuaH
LP Refrigerator use at high altitude
In the manual for my refrigerator in my Pop-Up it mentions changing a part when running on LP at high altitude. My wife and I are planning a trip in about a month to Northern New Mexico, some of the areas around around 10,000FT. elevation. Is this something I need to worry about? Any other things I should be aware of besides the obvious effects to myself.
    -- snip --
    It would help if we knew what trailer you have and the make and model of your fridge.
    Sometimes the propane burner will run rich at high altitude; replacing the orifice will solve the problem.
    The flame color will tell you if the mixture is correct/incorrect.
    Examples #1 and #2 are way too rich.
    Example #3 is borderline too rich.
    Example #4 is just right.
  • Spent two months this summer with my Dometic running on propane at 7000' and had no problems.
  • Some brands may perform better than others at altitude.
    Our RV tech warned us about our Norcold above 10,000', but we did not have issues with our weekend up above that level. Could be our fairly new unit performs better than what he's seen in the past.
  • We have crossed the Rocky Mountains several times with our fiver and never had any problems with using the refrigerator on propane.
