K3WE
Nov 05, 2013Explorer
LP Tank connections leaking
One of my LP tank connections (the one right at the tank) was leaking a little.
So, I put new connectors on (hose, big green screw ons, new brass insides) and darn if now they aren't BOTH leaking.
Is there some sort of O-ring / washer inside of the tank fittings that needs to be replaced?
It's not too bad, but the smell is unmistakeable. I was able to solve the problem by inserting a nice sized rubber washer- the washer was not designed for this use, but the fit was very good.
I'm ok with continuing this way- but then again, I'm not sure if I can sleep knowing that the LP-connection police could possibly cite me for this deviation from official process!
Thanks for any insight.
