Bobbo wrote:
4X4Dodger wrote:
An auto switchover regulator is a very good way to find your self with TWO empty tanks instead of one.
Turn on one tank and use it till it;s empty. Then turn the other on. It takes less than two minutes.
Not if you check the gauge every day or so. It is not install and forget. You still have to monitor it occasionally.
X2!!
Much easier to check every day or two, than to find out on a clod night you need to get up and open the second tank, or worse Wind and Rain!!
My gas is on 24/7/365, even when in storage. Why not i have lived in gas houses and it was on 24/7/365.
