Old-Biscuit wrote:
JoshuaH wrote:
I have a large solar panel that I charge my deep cycle battery with, never had a problem off grid camping so far. I also run a fridge and cookstove from the LP tank.
1 battery...1 night of Furnace
Then battery will be dead
Good luck!
Did you not notice that I have a large solar panel to charge the battery?
I have camped for 3 nights in a row in cold weather with no problems. I have also measured the current draw from the furnace, both the valve and the motor only draw about 1.5 amps at 12v, it doesn't drain the battery that quickly.
