JBarca's avatar
JBarca
Nomad II
May 08, 2018
LT Tire Replacements - All season
Time for new tires. Trying to find someone in the same weight range or that has been running their chosen brands close in the weight range listed below.
Currently using. BFG Commercial TA's LT225/75R16 LR E. 2,680# @ 80 psi. Now 5 1/2 years old.
Axles: 5,000# springs are the limiting factor.
Trailer GVWR: 10,000# Camper loaded: 9,920# GVW
Largest loaded axle: 4,400# aligned with 5,360# of tires/axle
Needs: I need/want to be able to run winter (below freezing) and summer temperatures on the same tires.
I have had 2 failures this year. This might be from 2 reasons:
1. It is not beyond impossible I ran into a patch potholes. The tires could have been damaged internally and manifested itself to the recent failures.
2. These current failed tires were also potentially made in the same BFG plant they had the recall on the next size from mine during 2012 when I put mine on. This may or may not have to do with the recent failures. BFG Recall
Mine look like this video. Tire shop showing recalled tires
I have a TPM system (Truck Systems TST) and the running pressures at 60 mph were 90psi and 89F stem temperatures when the failures occurred.
I'm not blaming the tires at this point, I want the best LT option within reason to replace them with.
New replacement choices I have found.
Michelin XPS Ribs: They are only a summer tire
Bridgestone Duravis R250: They are only a summer tire.
The above both have been reported to give excellent service however I need all season.
Bridgestone Duravis R238: Duravis R238 These appear to be an option as they are all season and similar tread as the R250's
Firestone Transforce HT: These appear to be an option, maybe not as heavy duty as the Duravis R238's Transforce HT
BFG Commercial TA 2: An upgraded version with "Cool Wedge shoulder insert" from what I already have. BFG Commercial TA 2's
BFG has had now 2 recalls in the Commercial TA's including the new 2 version. I linked 2012 one above and here is the 2015 recall. https://www.bfgoodrichtires.com/safety-recall.page
With that, I'm not real high on another set of BFG Commercial TA's.
Anyone with the same size, running all season tires? and other brands in the same or slightly higher weight range? Again need all season options.
I already went through the ST to LT upgrade. See here for wheel weights etc. ST225/75R15 to LT225/75R16 Conversion
Thanks
John
  • eHoefler wrote:
    An All Season tire is not necessary for a trailer. I have pulled our heavy fifth wheel with rib tires in the snow and ice with out issue. I have Roadmaster RM170 made by Cooper Tire on our rig
    I agree...John, IMO, you are over thinking this summer/winter tire thing. I have towed my 7-23 26' actual length enclosed snowmobile trailer on glare ice, passing the truckers going 35 mph in Montana, Idaho, and Wyoming, using truck 4WD. I sometimes towed on roads with deep snow, up to 1', with GY Marathons, without issue. Trailer towed great, but for trailer brakes, there were times, downhill in mountains, that chains on one axle would have been nice.
    I would just go with one of the proven Summer tires you mentioned.
    Jerry
  • An All Season tire is not necessary for a trailer. I have pulled our heavy fifth wheel with rib tires in the snow and ice with out issue. I have Roadmaster RM170 made by Cooper Tire on our rig
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Dec 22, 2025
