Dutch_12078
Apr 08, 2016Explorer III
Carvin Marvin wrote:
I installed my own pump on a 2011 RAV4 . Remco instructions are ideal. Almost impossible to screw up unless you tend to over tighten fittings. Had to remove the front clip. That was the most time consuming. As I recall start to finish less than three hours.
Yep! I did the pump install our 2002 RAV4 and later on moved it to our 2011 RAV4 when we bought it. I can't put a good time estimate on the pump part though, since I installed the base plate at the same time. The pump itself didn't take as long as the pump control and lighting wiring took I think.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
