TurnThePage's avatar
TurnThePage
Macerator question
I'm having to use my travel trailer into the fall and winter while it's tucked in my backyard. I have a cleanout about 50 or 60 feet away.
I've always been curious about a macerator kit. When you use one, how do you deal with the remaining water/stuff in the hose after you shut it off?
How does it do at or below freezing?
  • I dump the black tank and then the grey tank. My hose is on a reel that sits near the clean out so I leave that end in the clean out until the hose is reeled back up. That's usually enough as the grey water pushes everything from the black tank through the hose. If worried about any drip, you could just put a cap on the end before reeling it up.
    The macerator also has a port to run tap water in through it, so you could do that until it runs clear.
  • Bobbo's avatar
    Bobbo
    Explorer III
    I disconnect the hose from the macerator and lift it head high, walking the raised portion to the opposite end. That empties the hose, but does not rinse it out. I call it good.
    As far as below freezing, the macerator and hose are in the garage unless I am actively dumping. The garage does not get below freezing. I do not leave them out.
Looking for advice before your next adventure? Look no further.25,161 PostsLatest Activity: Sep 02, 2025
