- SlowBroExplorer IIIOk thanks everyone, I had a slight question in my mind wondering if length and its effect on the vehicle had more to do with the massive wall of box itself or the actual length.
As for towing calculations, I'm talking about the 110" wheelbase rule-of-thumb. I understand it is a verrrrrrrrrrrrrrrrry loose rule though.
http://www.rv.net/forums/index.cfm/fuseaction/thread/CFB/1/TID/307610.cfm - BedlamModeratorNo towing calculations take length into consideration, but whether to use one or two friction anti-sway devices is usually approximated using length. Overall length is important for camp site selection and ferry fees. If your tow vehicle is long or you tow doubles, additive lengths are important so you stay under maximum allowable where you plan to travel.
- VintageRacerExplorerWhat towing calculations do you do that use the trailer length? Just curious.
Brian - JesLookinExplorerIf you look at the brochures there is usually a statement saying that the model number is only the model number and is not intended dsecribe the length of the camper.
- APTExplorerMost TT manufacturers give model names/numbers which appear to be close to the box length. I would not assume the numbers in the model name relate to the length of the RV.
- Sandia_ManExplorer IIModel# and actual length will rarely be the same, on our rig we are nearly 4' longer.
- BedlamModeratorMost model numbers have vague reference to to cabin size. If it is a travel trailer, add 3-4' for the tongue. My Weekend Warrior FB2200 was a 22' front bath toy hauler that was 26' in overall length due to the 4' tongue.
- Use your measured length. Not all manufacturers use trailer model number to show trailer length. For example I have an Open Range 385RLS. The 385 stands for square feet of space inside.
- downtheroadExplorerSome manufacturers give the box length, others give the total length and include the tongue and bumper. (It's all over the place).
Makes sense to know the TOTAL length that I have to deal with behind my truck.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Dec 14, 2014
