wcjeep
Aug 25, 2014Explorer
W.E.BGood wrote:
"WARNING!!!
You need to replace those tires IMMEDIATELY. You've got the wrong kind of tires and they are going to fail due to overloading.
DON"T WAIT!! DO IT NOW!!"
A bit of Chicken-Little here IMO. I just finished a 4700 mile 3-week cruise from eastern Iowa to northern California with both interstates and VERY twisty mountain roads and 8% grades. My '08 Tundra with "dangerous" P-rated tires @ 40 lbs. handled it all confidently and comfortably towing my 7,000 loaded Outback 25 footer.
syndrome85...as others have noted, the original tire size/design/rating is different than what you have on it now. Use the existing pressure on the tire.
Your Tundra might have shipped with P rated tires?
The 1500 Megacab is a 3/4 ton truck. It has 3/4 ton axles, suspension, brakes and frame. Granted, the rear axle is the slightly lighter duty 3/4 ton version. No way this truck should be running light duty tires or wheels. If money is an issue look for factory take offs.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
