mrekim
Aug 04, 2016Explorer
Mixing Load Range D and E on TT
i have a ~35 foot TT with spread axles. I recently had the TT weighed and each tire has about 2,000 lbs on it. The current tires are ST225/75R15 D load rating. I've purchased 2 Maxxis ST225/75R15 E tires. They will go one one axle (Rear - only because that's where the spare is now). The bad tire is gone an the other tire will be kept as an off the rim spare.
I was originally going to run the E tires at 80 PSI and the D at 65 PSI. Will different tire pressures change the balance between the axles or will the equalizers on the suspension take care of that automatically?
