rav's avatar
rav
mixing NLGI2 grease with multi purpose grease
I need to lube the zerk on my B&W companion hitch and have NLGI2 grease in the gun, can I mix NLGI2 grease with multi purpose grease?
Thanks
  • https://www.bwtrailerhitches.com/sites/default/files/documents/2019%20Companion%20Owners%20Manual%20WEB.pdf
    page 24
  • rav wrote:
    I used the grease on the rubber mount, per the instructions I got with the hitch, other than that I did exactly as you suggested.
    Please show me your directions showing regular grease on the mounts, as White Lithium is what they recommend.
  • I used the grease on the rubber mount, per the instructions I got with the hitch, other than that I did exactly as you suggested.
  • Thanks for posting that vid!!!
    To keep things less messy (as shown in vid) I advise cleaning the hitch jaws and kingpin, then apply about one-two pumps from standard grease gun on the kingpin with your finger on the surface the hitch jaws contact.
    Personally I would not use the spray Lithium grease as it will get places you don't want it. I prefer a squeeze tube of the White Lithium Grease. I apply it to the top and sides of the rubber mount with my finger.
    Solvent is NOT required to clean any of the grease off. A paper towel works just fine!
  • Cummins12V98 wrote:
    It’s just fine. Bottom line is you understand there is a Zerk!!!
    Thank you- LOL sometimes you just need to read the manual.
  • Your hitch doesn't care what grease you put in it while your wheel bearings care very much that the greases are compatible.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Dec 29, 2025
