et2's avatar
et2
Motorhome / fiver comparison
We are using our new diesel pusher as I type. This is a first for us as we've always had travel trailers and fivers. I never thought I'd buy a class A. But getting older and a bad back and prodding from the wife led to our purchase.
Here are some of the things that stand out. Our MH is 42ft, old fiver was 39' and weighed 16000 loaded.
Steering does not respond at all like the 1ton dually, definitely a two hand job and no room for day dreaming. Constant minor corrections. Steering the fiver was definitely less stressful. The MH is like driving a big boat at slow speeds as it take a little time to react, so you pay attention to try not oversteering.
Ride was definitely better due to the air suspension.
Much better braking with air brakes.
View is superior when driving.
Better power, even though I had the same engine in PU.
Fuel - too soon to say
Noises you don't here in the truck ( expected) but not that bad.
Turning corners not as bad as I thought it would be.
Hooking up toad ( tow bars) about 10 minutes ( brake buddy too) but can probably get that down
Disconnection of toad about 6-7 minutes.
Setup at camp about 4 minutes to level and slides out,all from inside.
The rest of the hookup is the same.
Awesome room while driving.
Dogs love it instead of the back seat.
Tons more storage.
So in conclusion we really enjoy our decision, the only thing that probably needs getting use to is the difference in steering. Jus wanted to share my opinion for those who are on the fence.
Our choice was a 2013 Fleetwood expedition 40x
  • Sounds like You need to sort that steering out and soon!
    You may just need to balance Your weight to get more on the front end, or it might require an alignment.
    Properly balanced Your Rig should handle better than that pickup!
  • Glad you like the new rig. We have had a pup, a TT three different sizes of fiver's, but I do love my MH. Even if it is a C and not an A.
  • Steering can be fixed. I'm one handed on my old gasser.
