Aslag
Aug 12, 2018Explorer
I've received some good advice from a cross country travel trailer delivery driver that uses an Ecodiesel. When climbing keep the RPM under 3,000 and let the transmission pick it's gear. He got 360,000 miles on his first engine. You can get a compression brake option that closes the turbo vanes if the RPM exceeds 2600 while coasting. It is done by having your ECM reprogrammed by Green Diesel Engineering, you also get a few more HP and torque with the tune.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Aug 30, 2026
