bukhrn's avatar
bukhrn
Nomad
Apr 20, 2018
Mounting Flat Screen In Bedroom
I want to mount a 24" flat screen TV on an interior wall in the rear bedroom, after checking it out, I found that the wall is 1/2" plywood, covered with 1/8" decorative paneling, I've mounted a 38" piece of 1x10 across the whole area to screw into studs, (such as they are) at each end, with 5 vertical rows of 3 of 1 1/2" screws along the length, to this I will mount the wall mount.
I'm sure others have done similar, my main question is, has anyone had problems with the bounce of a 29' Class C in reference to a light (6.17 lb) tv hanging on a wall.
  • In my opinion, you're over-engineering and over-building this tremendously...not that there's anything inherently wrong with that. You have a mount that could probably support ten or twenty times what it needs to without flinching.
    I've yet to hear of anyone having trouble with a modern TV bouncing off the wall in an RV when mounted with a purpose-built mount. The TV itself won't be harmed by the bouncing, either.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 22, 2025
