Spud_45's avatar
Spud_45
mounting solar controller
I have a small 20 watt solar panel but it is a bit to small so I am upgrading to a 100 watt panel. With my small panel i never worried about overcharging so I never used a controller. Now with the 100 watt I am thinking i need a controller. so I ordered a controller with the panel I ordered. This system will be portable. I want to move the panel to the sun. The question is where do I mount the controller. I do not wish to drill any holes in my trailer. I would like to have it very close to the batteries. I am thinking of maybe mounting it in some kind of weather proof box but am worried about heat issues. Any thoughts or ideas would be appreciated.
  • Thanks to all who responded, I appreciate the input. I am going to mount the controller in the pass through.
  • My solar controller is mounted on the wall in the pass-through storage compartment near the batteries.
    Same here
  • My solar controller is mounted on the wall in the pass-through storage compartment near the batteries. I have a 150 watt solar panel on the roof and a 100 watt portable panel that I move around on the ground. I connect the portable panel to the controller with two cables that have 2-Pin SAE quick disconnect plugs.
    The first cable is around five feet long. It is always connected to the controller and runs through a hole in the floor of the pass-through storage. Yes, drilling a hole is necessary, but it is a small hole drilled through the plywood of the floor. Sealant was used in the hole where the cable exits the floor. The cable to the battery could be run through the same hole. The short cable under the trailer is attached with Velcro to the metal propane line that runs under the trailer. This keeps the short cable neat and tidy and out of the way. The cable is easy to reach, being just a few inches under the trailer near the pass-through storage door.
    The second cable runs from the portable panel and plugs into the first cable with a 2-Pin SAE quick disconnect plug. It is quick and easy to connect the portable panel to the controller. This configuration works great to provide extra charging power from the portable panel.
  • I had thought about the pvc electrical box, but I am concerned about heat in confined space. Thanks for the input please keep it coming.
  • The controller needs to be as close to the battery(s) as possible unless it has remote temperature compensation. It can be mounted in a pvc electrical box.
  • Why not mount it right on the back of the panel....
Looking for advice before your next adventure? Look no further.25,203 PostsLatest Activity: Aug 06, 2026
