- Rider7767Explorer
JAC1982 wrote:
Some of my neighbors have these. I watched one plow some snow with a back blade attachment and it made me jealous.
I am not plugging my YouTube channel, but I did a video of that very thing. https://youtu.be/G0dg6Ft-nfI - Rider7767Explorer
samsontdog wrote:
I used to help an man rebuild old Ford tractors growing up. He was always teaching me something. I love the old Fords. Rock Solid.
I have a Ford tractor that I use to move my TT around on my property. Works great - JAC1982ExplorerSome of my neighbors have these. I watched one plow some snow with a back blade attachment and it made me jealous.
- Rider7767Explorer
Dave in TN wrote:
I enjoyed your video. I love my sub-compact, but I know there are additional things it can be doing for me that I haven't used it for yet. I'm hoping to build a new crushed stone parking pad for my motorhome this spring and look forward to putting that bucket to use. Although, I'm a bit east of you in middle TN, and my land doesn't have one flat spot on it...so I'm learning that retaining walls are my best friend. :D
I lived in East TN, for a number of years. I understand what you are saying.
P.S. live in Smyrna for a while too. - Rider7767Explorer
George3037 wrote:
I CC this from another post so everyone could see the response.
I watched the vid and saw no mention that you put any weight in the loader. When you max out the 3 pt lift especially on a sub compact with the hitch back as far as yours was, for safety reasons make sure to put counterweight in the loader. That weight on the 3 pt of your tractor surely made the front end light and could have applied enough down pressure to lift the front of the tractor off the ground. I move my trailers around all the time but my tractor weighs more than my trailers.
The max 3 point hitch lift rating is without a loader. The loader is the extra weight. It also has the extra weight of the backhoe frame which is an extra weight the standard tractor does not have. The front tires never felt light at all. A good example was, the yard was soft and the front tires were marking it pretty bad. All was uneventful in the end. It is well within the tractors capabilities. I think lifting a bush hog up is harder, because the weight is so far back. Thank you for the insight. Always two ways of looking at things. A load of dirt in the bucket surely wouldn't have hurt. Well, maybe my yard! LOL. - I enjoyed your video. I love my sub-compact, but I know there are additional things it can be doing for me that I haven't used it for yet. I'm hoping to build a new crushed stone parking pad for my motorhome this spring and look forward to putting that bucket to use. Although, I'm a bit east of you in middle TN, and my land doesn't have one flat spot on it...so I'm learning that retaining walls are my best friend. :D
- George3037ExplorerI watched the vid and saw no mention that you put any weight in the loader. When you max out the 3 pt lift especially on a sub compact with the hitch back as far as yours was, for safety reasons make sure to put counterweight in the loader. That weight on the 3 pt of your tractor surely made the front end light and could have applied enough down pressure to lift the front of the tractor off the ground. I move my trailers around all the time but my tractor weighs more than my trailers.
- samsontdogExplorerI have a Ford tractor that I use to move my TT around on my property. Works great
- Rider7767Explorer
DrewE wrote:
Having done a bit of work a couple summers on a horse farm many moons ago, I can vouch for tractors being great for maneuvering trailers around. The combination of unobstructed visibility, the hitch close to the axle, and really tight turning thanks to wheel brakes makes backing a trailer into a tight spot almost easy. Granted, about all I worked with were hay trailers, but I see no reason why a travel trailer would be any different.
(A hydraulically raised hitch ball is also a very slick feature; we had one, too, though it wasn't a three-point setup on the 1950's vintage tractor we used most to haul trailers around.)
I grew up on a big farm plus around heavy equipment. We used a tractor to move trailers around all of the time. I have used my past subcompact tractors to move around my trailers, but I always tighten up when doing moving them with a new small tractor. - Rider7767Explorer
FunnyCamper wrote:
Sweet!
What we found is to not get too close to our detached garage, like yours, in that the 'damp' near it makes the vinyl get green and we have to pressure wash the side and that is more work. I would reverse the small trailer near the garage and put the camper out to keep that air and sunlight flowing to keep the 'moldy ick' off the side of the garage. JUST SOME suggestions! Do how ya like but for us this meant alot of sunlight hit the side and made it a better fit for us with less moldly icky hitting the side of the garage and making it nasty. Might be our location and weather etc. but we needed that air and sunlight to make a difference.
fun video!!
I will sure keep an eye on it. It has not given us any problem to this point. I kept it far enough away to be able to put the slide out, "out". Thank you for your insight.
Looking for advice before your next adventure? Look no further.25,117 PostsLatest Activity: Mar 12, 2025
