tuna_fisher's avatar
tuna_fisher
MPG difference?
I've been a TC guy(still have) and I just bought a 19'Toyhauler. The reason was the tank capacity as I boon dock all the time and usually at least a week or two. Showers will be nice after riding off road. My question is it has 100 gal. fresh tank and that's appx. 1200lbs. I drive a Duramax, How much do you think the difference in milage is with full water as apposed running empty? I ask cause a lot of times I can see finding a place to get water could be a real PIA. Also I'll have a empty truck to use.
  • atreis wrote:
    No noticeable difference. Wind resistance is by far the most significant factor in gas mileage for speeds over 30 mph.
    THIS^^^^^^^
  • rhagfo's avatar
    rhagfo
    Explorer III
    Wild Card wrote:
    You wont be able to figure a difference with 1200# added weight.
    X2
    That said use the 150 gal of water to balance the toys in the garage.
  • I just went to a new TT that's almost a foot taller and a ton heavier.
    So far it looks like I lost 1 mpg (at the most) but I need to do further testing.
  • I have a 6800 lb high profile TT and a triaxle gooseneck flat bed that is usually loaded to 19000 with a couple tractors. Similar towing routes, I get 1 mpg less with the TT.
  • I say less than .5mpg difference. Wind resistance is a bigger factor than a little bit more weight.
  • I have 10 years of data when towing my old trailer with my 06 DuraMax. 12 MPG over the years average.
    Bought a new trailer that is taller and 4K heaver. In a 1,100 mile trip with quite a few mountains I got 1.3 MPG less. 10.7 MPG. Speed was around 65 or so.
    Barney and the rest are telling you the truth.
  • No noticeable difference. Wind resistance is by far the most significant factor in gas mileage for speeds over 30 mph.
  • BarneyS wrote:
    Unless you are going up and down a LOT of hills or mountains, or doing a ton of starts and stops, then the weight of the water will not make any difference in your fuel mileage. It is the frontal area of the rig that makes the difference and the speed at which you tow it - not the weight. Once that weight gets rolling it takes very little HP to keep it going.
    Barney
    I tow it about 60-65 when possible. I know what your saying so what would you estimate the difference if driving mountains? I live in the desert but I go to the mountains, everything is up from here...
  • Unless you are going up and down a LOT of hills or mountains, or doing a ton of starts and stops, then the weight of the water will not make any difference in your fuel mileage. It is the frontal area of the rig that makes the difference and the speed at which you tow it - not the weight. Once that weight gets rolling it takes very little HP to keep it going.
    Barney
Looking for advice before your next adventure? Look no further.25,182 PostsLatest Activity: Jan 26, 2026
