vtchris's avatar
vtchris
Mr Buddy heater problem
I light my Mr. Buddy and all is fine......for about 2 minutes and then it goes out. I re-light it and then it stays lit just fine. Anyone have any ideas why it doesn't stay lit the first time. This is all on the same 1# canister and nothing else changes. It has happened many times in a row. I tried calling Customer support, but get put on hold and no one answers.
  • Well it turns out that I wasn't waiting long enough after the pilot light was lit. Now that I hold it down for a good 30-60 seconds (before I was just holding it down for "a bit") Mr. Buddy stays lit. Pays to follow directions!
  • Sounds like the pilot flame is weak and not making good contact to the thermocouple. Try doing what Don suggested,
  • I have to hold the pilot down for 30 seconds or so, then when I move the switch to whatever setting (low, high, medium) it stays lit until shut off or it runs out of propane.
  • vtchris wrote:
    But it doesn't "keep shutting off".....it just does it that once, the first light, and then it is fine.
    Hold the button longer.
  • But it doesn't "keep shutting off".....it just does it that once, the first light, and then it is fine.
  • From the manual:
    If Heater keeps shutting “OFF” during normal operation.
    CHECK
    • Pilot is blocked – clean pilot, see MAINTENANCE.
    • Provide minimum fresh air opening of 9 square inches (example 3” x 3” opening).
    • Tip over switch activated from bumping heater. Re-light.
    • Regulator defective - Replace regulator.
    • Internal contamination - Replace control valve and regulator.
    • Call Technical Services for additional information.
  • goducks10 wrote:
    Are you holding the pilot light down for 30-60 sec after it's lite? Then turn to HIGH till the element gets bright red then you can go to HI or LO.
    One thing I did find out a couple years ago is it won't run @6000+ feet el.
    Yes and yes. And I am at sea level.
  • Are you holding the pilot light down for 30-60 sec after it's lite? Then turn to HIGH till the element gets bright red then you can go to HI or LO.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 27, 2026
