vtchris's avatar
vtchris
Mr Buddy heater question
Can I run a Mr Buddy heater on just the pilot light?
  • At temps in the 30-40's overnight the low setting is too warm and yet just that pilot light on is just right. Seems to me the pilot light would burn less propane than having the unit on low with a window open. It has that oxygen sensor so that shouldn't be a problem. I ended up sleeping without it on at all and woke with it 40 inside and 32 outside. Tonight I will try it with the pilot on all night. I like the 4-9,000 BTU for it's ease of controls and it's compact size and when I want to warm up my space it does it fast. On the low setting it is perfect most of the time. I tried the smaller size and didn't like it. Thanks for all your help.
  • MrWizard wrote:
    IMO: if LOW is to 'warm'
    get a smaller heater with with less BTU output or open a few windows
    Agree
  • Eventually it could burn up some oxygen but it's doubtful it would be enough to cause any harm. Still can't figure out why you want to. It won't produce any amount of appreciable heat..They're so easy to light why waste the propane?
    B.O.
  • But is there any harm or danger?? That is what I really need to know.
  • IMO: if LOW is to 'warm'
  • There's a low and high power mode if it helps. Low power works just fine in many conditions, even after a 10 minute warm up on high.
  • I have a small camper and low is too hot right now (40's outside)
