Bob_Shaw's avatar
Bob_Shaw
Musty smell after sitting a long time
Despite one of my earlier posts about using Sunpacs, due to health reasons, my 5th wheel has set idle for the past 2 - 3 years, and has developed a bad musty/mildew smell. We took the couch out and put it into the house and the smell was enough to drive you out of the room, so the smell has permeated everything. We are planning to go camping (finally) in a couple of weeks, and we need to deal with the musty smell. So far we have used Fabreze on all the fabric, wiped down all of the woodwork, with the Fabreze dampened rag, used carpet fresh on the carpet, mopped the linoleum, and washed all the bedding. It smells much better, but is there anything else I can do to reduce/eliminate the smell? My next project is to wipe down all the walls with bleach water, and totally wash-down all the cubby's.
As far as I can tell, I do not have a leak, at least not one that is visible. The trailer did sit for a couple of seasons in Florida, without the Sunpacs, where I did not have enough power to run the A/C, which is what I think got the mildew/mold issue stated.
  • JaxDad's avatar
    JaxDad
    Explorer III
    Water, buckets or small wash tubs (mostly full) or water. Change the water every day, twice a day if you can.
    It's an old school hotel-keepers trick to eliminate odours.
