NamMedevac_70
Apr 04, 2023Explorer II
When everything else failed I chocked all wheels to the TT and pulled the holding pin on the ball shank in the Truck hitch and slowly and gently pulled forward and out came the ball shank. Then I was able to move the ball shank in different directions by hand until it popped loose from the TT tongue and fell to the ground. Safely worked for me but may not for others with no common sense.
Only had to do this a few times that was due to no choice parking location on uneven rough ground with binding on tongue and ball. Be careful your feet are not underneath the hitch ball when doing this and you are good to go. Yes, for the critics I did use ball grease and other standard stuff and it was still a no go. Electric jack trick did not work. Fishing and life is good. Cheers
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
