wildtoad
Jan 21, 2017Explorer II
A couple of things.
1) Check your tire pressures and if you don't get it weighed, use the GAWR's and set the PSI to what the tire manufacturer's guide says. The numbers may be less than what is on the placard. DO not use the tire sidewall numbers as they are meaningless on your motorhome.
2) Go over to iRV2.com and look in the Ford chassis owners section for a very long discussion on Cheap Handling Fix or just do a Google search. Don't spend a lot of money on stuff until you try the simple first.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 17, 2026
