intheburbs
Mar 28, 2014Explorer
davidgeminden wrote:
The cat scale readings indicated that the trailer axle weight exceeded the 4400 lbs max axle rating by 120 lbs when connected to the suburban with WD active.
You might want to check your door label.
Every half-ton Suburban I've ever seen from 2000-2006 has a 4000-lb RAWR, not 4400.
