I own a 2014 voltage 3305 and I have a water leak from winterizing last year. It is the black 3 way valve behind the wall where my red bypass/ winterize switch in the hook up station. I took it out bu...
The factory ones are really a cheap product very prone to freeze leaks and breakage when installing a new one. Find a 1/2 barb 3 way valve made out of brass, you'll be better off. If you want the factory one see the link below. valve
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 04, 2026
