Grit_dog
Jun 09, 2013Trailblazer
It's no sagging now but it will. Have yet to see a 1/2 ton truck that could hold up a 16-18' cargo trailer loaded.
Be wary of weight dist when loading your goods. You need some tongue weight but too much weight fwd or aft is a bad scenario for towing.
Personally I'd just beef up the back of the truck and call it good but a WD hitch will be better.
Good D or E tires on the truck is needed. Trailer tires should not be maxed out either and less then 5 yrs old. Trailer brakes are a necessity too.
Just drove the Alcan twice inthe last 2 months. Pulling trailers both times.
Maybe got lucky but with good tires rated for more than I was hauling I had zero flats. Knock on wood!
A co worker made the trip but he was loaded down looked like over gvw of the trailer. He had 3 blowouts on the trailer.
Don't forget to inspect, grease the the trailer axle bearings too.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
