Terryallan
Aug 02, 2014Explorer II
marcsbigfoot20b27 wrote:Terryallan wrote:Vannnce wrote:
Why do you say if its a diesel gearing down wont help? Down shifting my diesel holds me way better than any gas truck ever has. I can go down a 6% grade and simply pulling it out of overdrive or down to second will maintain my speed with my fifth wheel
If it does as you say. then it has some sort of after market exhaust, or engine brake or trany brake. diesels by design little to no engine braking in their natural state. Why? Because while they have tons of compression on the front side. All they have on the back side is a great big open hole. Nothing to create back pressure.
That is why Exhaust brakes were invented in the first place. To give engine braking to diesels, because they didn't have any. Having driven the big trucks. I learned the hard way. Diesels in their natural state, free wheel down the mountain, in any gear.
What are you talking about????
Diesels have so much compression that they like having 2 batteries to start them. Plus there is no throttle plate, so they are always sucking in as much air and compressing it if your foot is on or off the pedal causing enging braking.
Automatics are designed to freewheel or up shift when you let off the gas pedal in normal city driving so you dont feel the engine braking in top gear. Put one in 3rd or any manual gear in the city and cruise steady then let off the pedal, make sure you have your mouthpiece in before you bite the steering wheel.
The diesel I drove was not an auto. It was 13 speed Fuller road ranger. No engine braking.
Again guys. Exhaust brakes,,, AKA Jake Brakes were invented to give diesels braking, because they have NONE. IF, as many of you claim. Diesels have lots of engine braking. There would be no need for Exhaust brakes.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
