Bionic_Man
Apr 18, 2021Explorer
I'd also at least start with the truck you already have. Depending on the tongue weight of the trailer, you may be at or near the cargo capacity, but if you mind what you load with you, you will still be within the weight ratings. If you don't like the road manners of the set up, you can upgrade later.
If you upgrade, either the 6.4 or the CTD would be more than adequate. If you want to make sure you are much less likely to outgrow the next truck, skip the 2500 and move to a 3500.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 21, 2026
