DSteiner51
May 17, 2018Explorer
Lynnmor wrote:Terryallan wrote:Lynnmor wrote:
I would try to find a way to fix that Brakesmart, MaxBrake is also out of business and there are no controllers available that use your foot pressure as a reference. You likely will not be happy with the guesswork controllers that can only apply the brakes if your tow vehicle already has the ability to slow the combination.
Actually, That is not true. The Prodigy, and well every controller will apply the trailer brakes when you pull the manual lever. Weather or not the TV is braking. It is simply the best after market controller currently on the market. Millions of trailers are being stopped by some version of the Prodigy.
Now the Ford Factory brake controller will send braking current dependent on how hard you press the brake pedal. But with out a factory controller, prodigy is best
Actually the Brakesmart works like the Ford controller, a much superior method than the plug and pray guesswork controllers that you suggest.
Sorry, you had the best after market brake controller ever available. Now any other will come up wanting but that is the way it is. The Prodigy will most likely be the best you can currently find unless you trade up in trucks to get factory.
Looking for advice before your next adventure? Look no further.25,190 PostsLatest Activity: Mar 30, 2026
