Lynnmor
May 17, 2018Explorer II
memtb wrote:
JMO. If it’s an inertia type controller, and you are on ice.....when braking the truck you will get little to no inertia, thereby “no” braking to the trailer! Am I correct in this assumption? This was much of the reason we went with the Brakesmart!
You are correct. While some talked about ice, something as simple as wet leaves or mud in a campground might leave you wishing that your foot controlled the brakes. The idea that your trailer brakes will only assist if your truck already has the ability to stop is almost funny. Since few would not spend the money, or didn't understand the function or were too lazy to hook up an additional circuit, we are left with the current crop of guesswork controllers. At least the truck manufacturers understood the merit of a driver controlling the brakes and used a system almost as good as the Brakesmart.
Looking for advice before your next adventure? Look no further.25,190 PostsLatest Activity: Mar 30, 2026
