steveandjil's avatar
steveandjil
need general advice
Hi Folks,
New Winnebago View 24M. Pulled a 5er for over a decade. We want to be able to tow our 4WD Wrangler. Need suggestions on tow bar, baseplate, and supplemental breaking. I want EASY and safe to use.
Also, from what I can guess, I will need to have the jeep key in accessory mode, so the front wheels are not locked. I assume the connection from hot connection on coach to toad will keep battery from dying.
Thanks in advance for any advice.
Steve
  • Bobbo's avatar
    Bobbo
    Explorer III
    Check the baseplate installation instructions for each manufacturer to pick the most secure baseplate.
    ReadyBrute Elite tow bar/surge brake is your best bet.
    Unless you run a charge line, nothing will keep your car battery charged. That is not part of the normal setup. You can either disconnect the battery, remove a fuse (possibly), or run a charge line. The charge line can be either through the umbilical or separate.
