landingzone's avatar
landingzone
Need guidance on best roof trailers
I will soon be in the market for a used camper for a permanent vacation site. It will likely be 5-10 yrs. old and 30ish ft. long with slides. Are there any makes/models which have seemed to stand above the rest for not leaking? What should I look out for? Is it reasonable to find a trailer of this age that won't need roof repair fairly soon? Thanks.
  • The longest lasting roofing material is aluminum. Still not perfect as there will be seams that are potential leak points.
    Any trailer that is 10 years old and not had EXCELLENT care (wash and treat with UV resistant spray) is going to need a new roof (NOT A RECOAT) soon.
    A carport type covering is your best solution.
  • Roof maintenance is the key. Check those records closely on a used RV and do maintenance at least twice a year.
  • Most all RVs have rubber roofs and are sealed around the edges and the penetration points like vents, etc. How well the trailer was maintained has more of an effect on leak resistance than a particular brand. I would think if you are doing a seasonal site especially in upstate NY you would want to build something like this:
