Lynnmor
Aug 30, 2021Explorer II
To get the proper weight transfer, your owners manual says this on page 281:
Weight-distributing Hitches
WARNING
Do not adjust the spring bars so that
your vehicle's rear bumper is higher
than before attaching the trailer.
Doing so will defeat the function of the
weight-distributing hitch, which may cause
unpredictable handling, and could result
in serious personal injury.
When hooking-up a trailer using a
weight-distributing hitch, always use the
following procedure:
1. Park the loaded vehicle, without the
trailer, on a level surface.
2. Measure the height to the top of your
vehicle's front wheel opening on the
fender. This is H1.
3. Attach the loaded trailer to your vehicle
without the weight-distributing bars
connected.
4. Measure the height to the top of your
fender a second time. This is H2.
5. Install and adjust the tension in the
weight-distributing bars so that the
height of your vehicle's front wheel
opening on the fender is approximately
a quarter the way down from H2,
toward H1.
6. Check that the trailer is level or slightly
nose down toward your vehicle. If not,
adjust the ball height accordingly and
repeat Steps 2-6.
Once the trailer is level or slightly nose
down toward the vehicle:
•Lock the bar tension adjuster in place.
•Check that the trailer tongue securely
attaches and locks onto the hitch.
•Install safety chains, lighting, and trailer
brake controls as required by law or the
trailer manufacturer.
WARNING
fender. This is H1.
connected.
toward H1.
repeat Steps 2-6.
Looking for advice before your next adventure? Look no further.25,207 PostsLatest Activity: Aug 26, 2026
