bobby7718
Aug 31, 2021Explorer
thanks you all for chiming in. Brand new user of this forum. I updated this thread a few times with the pics, hopefully this time the pics should show properly. Attach the pics here in case the original one are still not refreshed.
Prior to the second visit to the dealership for the last adjustment, I have read through the sticky threads of WD hitch(which was super helpful)and was able to adjust the hitch a bit, but still bouncing on the way to the store.
My next attempt will be : try to adjust the tilt-head downwards a bit to produce slight more tension on the bar, hopefully will bring down the front fender(H2) a bit towards H1.
In the mean time, I also realized that the tire(or the tire pressure) might contribute to this after read ***Link Removed***.
I checked my tires and the pressure, which is what I have right now.
- 275/65R18 116T , Max Load 2756 lbs, Max Press 50 PSI.
I also noticed that my current 4 tire pressure are all 40 PSI, yes, I didn't max out the tire pressure before the towing. I will max the rare to 50 PSI, the front 48 PSI as the next try.
Will report back. Yes, will plan a visit to CAT scale get the weights.
Looking for advice before your next adventure? Look no further.25,207 PostsLatest Activity: Aug 26, 2026
