CampingN.C. wrote:
Chris Bryant wrote:
Sounds to me like a pinched copper line, or a bit of debris in the orifice- a restriction to the LP flow.
I think you nailed it. I thought I had it going but it started to act up again. I called the dealer today and before I fully explained the symptoms he said it was debris, which is odd because it's been in a garage all summer, but that's my luck.
Of course it's not covered under the warranty. And of course it cannot be removed from the exterior, lovely !!
I'd suggest to break out the air hose again and this time direct it into the intake port. You could also blow back through the exhaust to make sure any debris is moved out of the ignition area.
