dcmac214's avatar
dcmac214
Need Help with Utility Trailer Decision
Need to get 10-12' utility trailer primarily to haul our SxS UTV behind the coach. On occasion to haul mower or small tractor for service (TV for that will be the pickup).
Am I better off getting the deck made with 2x6 treated wood or with 1/4" steel diamond plate? And why?
Everything else is the same except for total weight and cost, and they're so close wood vs steel it's negligible and irrelevant.
  • I would go with the steel. Most utility trailers are store outside when not in use, making them more prone to weather damage. The steel open deck allows for debris from objects carried to fall through keeping deck cleaner.
    In the event you haul small items, you could simply lay a tarp to prevent boxes or the like from moisture and road debris.
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Feb 27, 2025
