guidry wrote:
You talked about sway then about your weight distribution; two different things. Get the trailer level and you want weight distributed to the front. Use sway control bars to control sway. You should have someone knowledgeable help you because if you get sway and there’s not enough weight to the front of your truck you’ll have problems. You’ll also need to know how to control the sway from your brake controller without losing control. Get someone from your local dealer to show you how to set everything up properly.
I feel pretty confident in setting everything up. I bought the weight distribution hitch to help with the sway. I wasn't getting crazy amounts of sway when I towed it, just occasionally and when trailer trucks would pass me.
