Tvov
Jul 24, 2014Explorer II
Well, you probably won't have anyone else bothering your hose -- purple colored water lines and connections usually mean non-potable (do not drink) water. This may be a regional thing, though.
Hmmm.. on reading the link, the manufacturer states it is "safe to drink from" - which is fine, just seems odd that they colored the hose purple. The reviews mostly seem good!
chakatania wrote:
I'm going to try this hose I found on Amazon that seems to be able to take everyday heavy usage....and supposedly high water pressures....and YES...different then the white hoses in color but is "Lead Free"
http://www.amazon.com/dp/B006CFYD9Q/ref=pe_385040_121528360_TE_dp_1
It's purple or "eggplant" colored! Will have to repost an update or review after I've tried it.
- Manufactured in the United States using 100% lead-free, BPA-free, top quality, UV stabilized FDA & NSF grade polyurethane
Solid chrome-plated machined brass fittings provide a long-lasting, never-tarnish, durable hose fitting which also prevents lead from leaching into the water
Specially engineered strain reliefs on both hose ends to prevent hose kink; Flexible in all weather conditions, even freezing temperatures
4-5 gallons per minute flow rate--plenty for most any job around the home, garden or shop
Soft, flexible and effortless to use; Hose weighs only 3 pounds for every 50 feet
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Apr 25, 2026
