Bumpyroad
Jul 24, 2014Explorer
Tvov wrote:
Well, you probably won't have anyone else bothering your hose -- purple colored water lines and connections usually mean non-potable (do not drink) water. This may be a regional thing, though.
Hmmm.. on reading the link, the manufacturer states it is "safe to drink from" - which is fine, just seems odd that they colored the hose purple. The reviews mostly seem good!chakatania wrote:
I'm going to try this hose I found on Amazon that seems to be able to take everyday heavy usage....and supposedly high water pressures....and YES...different then the white hoses in color but is "Lead Free"
http://www.amazon.com/dp/B006CFYD9Q/ref=pe_385040_121528360_TE_dp_1
It's purple or "eggplant" colored! Will have to repost an update or review after I've tried it.
- Manufactured in the United States using 100% lead-free, BPA-free, top quality, UV stabilized FDA & NSF grade polyurethane
Solid chrome-plated machined brass fittings provide a long-lasting, never-tarnish, durable hose fitting which also prevents lead from leaching into the water
Specially engineered strain reliefs on both hose ends to prevent hose kink; Flexible in all weather conditions, even freezing temperatures
4-5 gallons per minute flow rate--plenty for most any job around the home, garden or shop
Soft, flexible and effortless to use; Hose weighs only 3 pounds for every 50 feet
I saw a blue one at WalMart a while back that was labeled for drinking water. what exactly is 'FDA grade polyurethane? and most all hoses sold in the USA are probably "safe to drink from".
bumpy
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Apr 25, 2026
